Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-16-2004, 07:17 PM
BRARUN BRARUN is offline
Question Factory Gauges
I GOT A 95 SATURN I UNPLUGED THE FACTORY GAUGES AND NOW ICAN'T GET THEM TO WORK ANY HELPFUL TIP WOULD BE GREAT BECAUSE I'M
Old 03-17-2004, 11:54 AM
streetracr32's Avatar
streetracr32 streetracr32 is offline
Re: Factory Gauges
maybe you shorted out some of the wiring, or plugged wires into the wrong inputs. do u have a wiring diagram???
Old 03-17-2004, 02:04 PM
Re: Factory Gauges
no diagram but i am going to get a cluster and a dash wiring harness form the savage yard and pull them as a unit i think there is a short somewhere i have a 91 saturn for parts but its different it has abs on it and the control mod. will run the motor fine but will not control the trans properly so i don't think the wiring harness on it will work
Old 03-17-2004, 02:09 PM
Re: Factory Gauges
my inputs on cluster is black on the left side and white on the other i can put in the black the high beam indecator comes on and it is shorted to the turn sigal relay and tring to fry it
Old 03-18-2004, 10:13 AM
Re: Factory Gauges
sorry i cant hlp u very much... i dont have tonz of experience w/95s... but i'll se what i can do...
Old 03-18-2004, 11:08 AM
Re: Factory Gauges
update fixed i replaced under the hood fuse box,wiring harness, cluster, and fuse box under radio/ac when to the U-AUTO PULL-IT cost for all of that $100.00 plus $3.00 memdership fee for a year
Old 03-19-2004, 09:47 AM
Re: Factory Gauges
you might have bent one of the pins putting it back in, or switched the terminals around. u said u were using a 91 for parts??? in that case, if u switched the gauges and parts around, they wouldnt work, because the vin #'s dont match up, and worse case senario, u would have 2 get ur ecu re-flashed, which costs a few grand!
Old 03-20-2004, 10:18 PM
Re: Factory Gauges
no what i mean i have a 91 which i did not think would not work so i bought parts out of another 95 and that fixed it
Old 03-20-2004, 10:20 PM
Re: Factory Gauges
but i thank you for tring to heip
Old 03-24-2004, 10:51 AM
Re: Factory Gauges
right, if u bought parts from a 95 to put in ur 91, then the VIN #'s wont match up. they have 2 b the same year to be compatible.
Old 04-03-2004, 03:45 AM
LitRed2 LitRed2 is offline
Re: Factory Gauges
I have a 1992 saturn,sl2,sudan. The dash wont read my gas gage, nor my tempeture gage propertly.The go back and forth. Whats wrog?
