Old 03-16-2004, 07:10 PM
gmc gmc is offline
baking soda vs vinegar
Which one of these would work better to clean the corrosion off of my batery cables? I'm sure there's better things out there, but since I have these items already, why not try em?
Old 03-16-2004, 08:45 PM
WorkinOnACavi WorkinOnACavi is offline
Re: baking soda vs vinegar
I would use vinegar dont know why but it seems like a good guess
Old 03-16-2004, 08:54 PM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Backing Soda and HOT water, mix it together in a bowl, and poor it onto the bat. Then use a tooth brush and clean the corrosion.
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 03-16-2004, 09:12 PM
BlueBomber's Avatar
BlueBomber BlueBomber is offline
Baking soda cleans everything.....
"I'm not as think as you stupid I am"
Old 03-17-2004, 06:16 AM
heh I typed Backing Soda. anyway Baking soda eats the corrosion and makes a chemical reation it is kinda cool turns everything a light light blue, untill you was it off.
Old 03-17-2004, 05:52 PM
amac209 amac209 is offline
Send a message via MSN to amac209
mix baking soda with some water. baking soda is a base so it neutralizes the acid in the corosion. vinegar is an acid so it won't react with the corrosion.
Old 03-17-2004, 06:22 PM
urweak urweak is offline
Banned
Send a message via AIM to urweak
yes backing soda is what you need to use, i did this about a month ago when i relocated my battery to the trunk, and had to clean up the connections on the wires. i just got some baking soda and hot water, threw the parts into the mixture and it foamed up instantly and removed all the corotion no problem.
