Old 03-16-2004, 06:06 PM
Gilmb Gilmb is offline
1991 f150 automatic trans. problem
Hello, I have a 1991 f150 5.0L with auto transmission with electronic overdrive. I need help figuring out what to do as it revs up when in gear but does not move. For the past while the truck would not shift gears smoothly. Sometimes the motor would rev-up between gears. The other day I was driving up an incline and the truck would not kick out of overdrive. By the time I could press the override button the engine reved up and the truck decelerated. The engine then stalled. Battery had some juice but not enough to turn the motor over. Towed it to the garage (rear wheels lifted). Garage put 7 liters of oil and said it worked during his short test drive. Went to pick it up and the truck will not move. The engine does not even drop in rpm when put in gear. Oil appears dark but no strong smell. Do I need a new transmission or should I check something else?
Any suggestion
Thanks
Old 03-17-2004, 02:07 PM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Re: 1991 f150 automatic trans. problem
Charging system has to be working correctly before anything else. 7 liters???Whoa. Maybe it pumped it all out after/during their road test. Should be pretty obvious where that much fluid leaked from(Front seal area, or cooler line). Check the fluid level again. Low side of stick, engine running in park.
Old 09-18-2004, 06:54 PM
CanadianF150 CanadianF150 is offline
I am having pretty much the same problem with my 93 F150 in gear it's fin but if i shift to neutral or park it revs right up, when it shifts between gears it gives you a good kick you know it's shifted
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
