Old 03-16-2004, 03:20 PM
3000GT4ME 3000GT4ME is offline
Send a message via AIM to 3000GT4ME
weird noise when i turn the car off
As you probably already know i have a 1996 base 3k and i recently have been noticing that when i turn my car off, when the engine stops spinning, and when i open my door i my garage i have been hearing like a small grinding sound coming from the engine. Does anyone know what this may be? I am getting kind of worried.
Old 03-16-2004, 03:41 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
You mean after the car shuts off you then hear a grinding sound? Do you hear it at all if the car is running?
Resistance Is Futile (If < 1ohm)
Old 03-16-2004, 04:16 PM
Re: weird noise when i turn the car off
I dont here it when the car is running but i guess it is possible and i just dont here it. It is hard to explain.. just a grinding sound as the engine comes to a stop
Old 03-17-2004, 12:52 PM
NightRiderGT NightRiderGT is offline
does it soumd like a loud mouning/ hising noise. because the same thing happens with my sl since i took off my resignator bottle and put a filter on. it could be the air flowwing through the filter. or i could be completly wrong. it wouldn't be the first.
Old 03-17-2004, 01:54 PM
Igovert500's Avatar
blue + red light magnet
Well an open element filter would make the noise nightrider is describing, tahts normal. but that sounds like a vacuum, not a grinding, so i doubt thats the solution. Can you trace where the sound is coming from? And does it sound like metal on metal?
Old 03-17-2004, 03:34 PM
I do think it sounds like metal on metal.
Old 03-18-2004, 09:33 AM
Igovert500's Avatar
Just the obvious...did you check your oil? Perhaps its low or should be changed.
Old 03-18-2004, 11:16 AM
Nesryn Nesryn is offline
Send a message via MSN to Nesryn
Doesn't low oil make a clicking noise? And wouldn't he hear it when driving, especially at higher RPM?
