Old 03-16-2004, 01:05 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
Question how long will this last me?
hey guys, i recently bought a 92 Civic hatchback for $1300. it has about 146,XXX miles on it. i discovered that the cylinder head gasket is cracked, the valve gasket is cracked, CV boot is cracked, flywheel is worn like a mofo, and the radiator is doing anything. if i were to fix all of these to be like brand new, how much longer would this car last me? i'm thinking about 3-4 years, but i could be wrong. tell me what you guys think.
Stock 1992 Civic DX hatch
Old 03-16-2004, 03:15 PM
mjshort18 mjshort18 is offline
Re: how long will this last me?
that estimate sounds about right, could be longer.
Old 03-16-2004, 06:13 PM
so your saying that this will definately help the life of my engine?
Old 03-16-2004, 06:29 PM
yeah as long as nothing else major happens and if your fixing all the things that need it. i could be wrong though, just make sure the rest of your engine is good.
Old 03-17-2004, 10:41 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
do the head, and valve gaskets, and radiator first... You can replace the flywheel when it's dead, and you can repack the CV joint yourself for cheap.. (parts cleaner, grease, and a new boot/boot clamp) you can do most, if not all of this yourself if you have the right tools..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
