Go Back   Automotive Forums Car Chat > Land Rover > Discovery | LR3 | LR4
Old 03-16-2004, 07:08 AM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
Question shifting into 4 wheel Low??
Recently My father Purchased a 95' Land Rover Discovery in beautiful shape, For the life of us we Cannot figure out how shift it into four wheel low.. I've tried Neutral, rolling slowly in Drive the damn shift lever on the floor wont budge.. Any Ideas or suggestions would be greatly appreciated. Im thinking because these trucks are so advanced Im looking past something,
Thanks, Jimmy
Old 03-16-2004, 12:16 PM
Cbass94's Avatar
Cbass94 Cbass94 is offline
Send a message via MSN to Cbass94
Re: shifting into 4 wheel Low??
While driving slowly, put the main shift lever in "Neutral" so you are coasting in neutral. Now shift the transfer case lever from HI to LOW. Once you feel it engage, put the main shift lever back in "Drive" (or in gear if it's a manual) and away you go.
Just a side note, to lock the center differential, you can be in any gear going any speed, you just have to make sure you are going in a straight line. Then slide the transfer gearbox lever into or out of Diff lock.
If you are still having trouble, I would check with a dealer.
Best,
-Brad
Old 03-16-2004, 12:28 PM
RACER D12's Avatar
RACER D12 RACER D12 is offline
Send a message via AIM to RACER D12
It could be jamed in which case...I for get what your suspost to do. Just look in your manual
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows
Old 03-16-2004, 03:23 PM
Jimmiz71's Avatar
thanks guys.. next time Im over there ill give it a shot.. the Troy McClure pic is hillarious!!
Thanks, Jimmy
Old 04-07-2004, 05:07 PM
100th96cobra 100th96cobra is offline
when slowly rolling in neutral, put the diff lock into neatral...dont do it all at once. then when you hear the beaping, put it into low, then push over to the left
