Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-16-2004, 12:56 AM
Samurai0 Samurai0 is offline
Unhappy Engine is loping sometimes
Hi,
I've noticed something recently where the engine lopes a bit, or may even seem to want to konk-out when shifting between the D & R shift positions (like in a 3-point turn).
Anybody run into this?
Old 04-05-2004, 12:37 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Engine is loping sometimes
Yeah, I have an 87 with the same thing happening, as well as dying at stop lights. It was idling really slow, so turned up idle screw a bit and that seemed to help. I'm also looking for a vacuum leak somewhere.
Old 04-06-2004, 03:06 AM
Re: Re: Engine is loping sometimes
Hmmmm.
Idle screw? Where's the idle screw?
Do you have EFI?
Hmmm.
Yup. It's like the idle is tooooo lowww.
I'm gonna check out the airflow sensor too, because I believe the thing
is using way to much gas.
Anyway's I can't wait until it's 25yo In New York, cars at 25 years have no emissions requirements anymore.
I can't wait to swap out the electronic emissions $hit for a 4 barrel holley and racing edelbrock manifold.
Old 04-06-2004, 06:11 AM
Yeah, it's a 5.0 with EFI; looking from the front of the vehicle, the idle screw is just to the left of the air filter box, and just below the aluminum intake. On mine it's behind a couple of sensor wires. Clockwise will increase the idle.
I'm sure there are some sensors that are dying, or maybe the cumulative effect of age on all that electronic stuff. That's why you'll see original 60's cars, but hardly any early FI cars...all the electronics die and you can't fix it without selling your house.
Old 04-27-2004, 11:12 PM
peterand peterand is offline
I had trouble with mileage, loss of power, stalling. I had it into the garage a few times and spent a couple grand. It ended up being the Cadilatic Convertors were partly plugged. Blew them out and all was better. My mileage went from 18Mpg to 32Mpg.
Old 04-28-2004, 12:30 AM
How'd you "unplug" them? You must've had to have them cut down, and welded back in.
Old 04-28-2004, 06:50 AM
Wow, blew out the cats and went up to 32mpg? This is an old merc grand marquis with the 5.0? I think I'll have to do the same!!!
I know that some folks just take a 1" drill bit and put a hole through the middle to keep some of the pollution control ability; I've also heard of some that just took out all the material in the converters, their veh still passed emissions.
Old 04-29-2004, 11:56 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
i no were the screw is
ok on the 4.6 leter v8s in the merc if u fallow the air box all the way to the intake theres the lever were u can control the intakeand if u look at it theres a little black stud like thingy take a pair of pliers and make sure the engine is running and adjust it to were ever u want another thing i found works to control the idel is clean the inside of the throttle body then adjust the throttle positioning screw good luck
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 04-29-2004, 05:10 PM
I think......If you gut the CAT's then you're making an 'expansion chamber' where the hot gasses could be given a bit more time to "burn".
I've seen this on some small cars, but the CAT's on my car are 3-way (air injected), to force extra combustion.
Hmmmm.
Engine loping Loekee75 Park Avenue 4 01-18-2007 10:04 AM
Engine lopes when idling Theguy427 Focus | C Max 3 06-24-2005 04:30 PM
PCV valve replacement & engine loping DLHeck Grand Marquis 2 06-06-2005 09:08 AM
Engine Loping. Johnny Fargo M Bodies 5 04-02-2005 06:30 PM
engine loping Mad1 Ranger | Courier 5 07-12-2004 06:51 PM
