Old 03-15-2004, 06:46 PM
spayordie spayordie is offline
rear struts 90 std: Spring compressor?
Probably a simple question...the manual talks a lot about needing a spring compressor for the front struts, but basically just says to unbolt the strut on the rear. Does it in fact need a spring compressor?
Old 03-15-2004, 07:24 PM
crx91's Avatar
crx91 crx91 is offline
Re: rear struts 90 std: Spring compressor?
yes u do.the spring is still comp so if you just try and do it like that then u might get hurt.jus go to the nearest automotive store and they will lend u them with a 25 dollar diposit.
