Old 03-15-2004, 06:45 PM
aznnutty aznnutty is offline
engine swat, sl to vr4?
i currently have a 93 SL, i would like to have a vr4 engine, but is it possible to swop the engines or should i just save up and get a vr4? how much for the swop?
Old 03-15-2004, 06:49 PM
Igovert500's Avatar
blue + red light magnet
Re: engine swat, sl to vr4?
Read other posts on this forum. Plenty of people ask the same questions. Its a difficult job, and you're gonna have to find a vr4 that's willing to part with its engine and turbos. (ie. wrecked). Then you will have traction issues to deal with...might just be easier to go vr4, unless you want to keep the FWD...
Old 03-15-2004, 06:55 PM
Nesryn Nesryn is offline
Send a message via MSN to Nesryn
Yeah I would say save up for a VR4... The FWD is what stopped me from doing a swap. 'Cause I have enough traction issues as it is right now, I couldn't imagine what it would be like if I put more power in it.... Can't beat AWD...
Old 03-15-2004, 09:58 PM
Hotshot8792 Hotshot8792 is offline
i'd go for a vr4 for a couple of reasons
first off, your gonna have traction problems
not only are you gonna have to find an engine with complete parts, your gonna have to either have the skills to install it yourself or pay someone else to install it
next your gonna have to spend another grand for LSD or else you'll blow a hole in you transmission and have to buy a new one
you will also have to upgrade your clutch because your oem clutch will burn out within 500 miles
even with LSD, you will wont get the traction that a VR-4 has, after you get going, you will start to pull on the vr-4, but then the fwd mtx gearing kicks in at 4th gear and the vr-4 will pull away like nothing because of taller gears
reason i have fwd tt #1 i'm atx so i dont have near the traction problems, i can actually get through first without spinning at all, #2 i wanted an automatic turbo, #3 i didnt need LSD because my tranny does not have as much stress on it, #4 i have taller gears than the fwd mtx and therefore can still move after 105 which i proved when racing a vr-4 up top
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 03-16-2004, 11:44 PM
SilverStealth SilverStealth is offline
Hey, SpeedFreakSteve on 3si.org http://www.3si.org/forum/showthread.php?t=198122 is swapping his SOHC for a TT, plus he's changing over to AWD. He's documenting the whole thing, he'd be a good guy to talk to.
Old 03-17-2004, 09:34 PM
dlm21jr dlm21jr is offline
Send a message via AIM to dlm21jr
vr4 engine with tranny
I have found a vr 4 engine and the awd tranny id like to put it in my 91 sl. Am i going to have any issues fitting evertyhing in and what else will i have to change to make it awd.
Old 03-17-2004, 10:28 PM
to convert to AWD, you will have to do a whole lot of custom fabrication to the rear as the rear frames on the AWD cars are different from FWD cars. You better have some knowledge and access to a VR-4 parts car if you want to convert to AWD
Old 03-19-2004, 11:51 AM
alan92rttt's Avatar
alan92rttt alan92rttt is offline
check this faq out
http://www.3si.org/forum/faq.php?faq..._tt_conversion
Alan Michigan 3S
The Toy 1992 Dodge Stealth RT/TT 13.3 @ 102mph
The Daily Driver 1998 3000GT SL
www.3sgto.org - The New home for 3S Enthusiasts
Old 03-23-2004, 06:02 PM
thanks
Thanks for the links!!
