Old 03-15-2004, 06:39 PM
cykryn cykryn is offline
Replacing a dual mass flywheel a standard one?
I have a 97 F-350 5 speed powerstroke, with a broken dual mass flywheel, I have the option to go with the standard dual mass or an after market single or standard fly wheel?
Has anyone tried this out?
What are the pros and conn’s?
Which one is better?
Thank you for any info!
Old 03-16-2004, 12:12 AM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Have replaced a few with standard flywheels. You can get some different noises and vibrations but not too bad. Most people don't even notice the difference. With the dual mass you can change bolts in the pressure plate to remove vibration and moaning noises. The dual mass also provides shock-load protection for the drivetrain. If you want to maintain "luxury car" feel, then stay with dual mass. Good luck
Old 03-16-2004, 10:18 AM
is it safe for my drivetrain? will I lose troq or have problems with loads or unloaded? Thank you for replying!
Old 03-16-2004, 10:59 AM
RexNfx400's Avatar
Re: Replacing a dual mass flywheel a standard one?
I haven't heard of any paticular failures or torque complaints from a standard flywheel setup. You'll be safe. Just different noises that you might not be used to.
