Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-15-2004, 04:16 PM
boarderbrad158 boarderbrad158 is offline
Send a message via AIM to boarderbrad158
Cool GSR swap for a 99 civic ex/ d16 turbo
I was wondering how difficult it would be to swap my 99 automatic d16 for a 5 speed b18. Is it worth getting a 5 speed, or should i stick with an automatic? Also is it worth getting a b18, or should i just turbo my d16?
Old 03-15-2004, 08:06 PM
pr.OJ.ect CRX pr.OJ.ect CRX is offline
Re: GSR swap for a 99 civic ex/ d16 turbo
well that all depends are how deep ur pocket is and how much power your looking for. i think u have the D16Z7 127 hp @ 6600 107 lb-ft torque @ 5500.
there a couple of differ b18 engines that you look at the best and most expensive is the b18c from the type R 210hp@8100rpm 134lbs-ft@7500rpmwill run you about $4,400 or around there. or you can go with the b18b non vtec from LS 142hp@6300rpm 127lbs-ft@5200rpm
goes around $1800. , but if i had your car i would look into seein if you can get a h22a 202hp@6800rpm 161lbs-ft@5500rpm for almost nuttin $2,300
ps. go stick man you dont know what your missing
________________________________________________
NO MATTER HOW FAST UR CAR IS, MAKE SURE UR REFLEX IS FASTA
car: 1989 Honda CRX hf
mods: None yet...
occupation: i do custom graphics for cars trucks bikes and anything else a sticker can stick on.
check out my site - www.oneshotgraphics.com
Old 03-16-2004, 04:14 PM
thanks man, that helps
Old 03-16-2004, 04:17 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
A turbo d16 with only 6psi will be faster than having a stock B18C1, gsr engine. If you turbo the gsr engine your car will fly if you install wings.
Old 03-16-2004, 10:20 PM
Re: Re: GSR swap for a 99 civic ex/ d16 turbo
i dunno man d-16 turbo vs a gsr i would like to see that match
how about h22 u think that 'll work for him
mods: None yet...
Old 03-17-2004, 10:20 AM
Ricochet's Avatar
Banned
Re: Re: Re: GSR swap for a 99 civic ex/ d16 turbo
My friend installed a base turbo kit on his '00 EX for like $2,000 and it put down 175whp and 170wtq. Just the GS-R engine alone costs $3,000 - $3,500 then you gotta buy parts and everything assuming you install it yourself. They only put down 165whp and about 125wtq.
Old 03-17-2004, 03:18 PM
chechin chechin is offline
Send a message via Yahoo to chechin
Re: Re: Re: Re: GSR swap for a 99 civic ex/ d16 turbo
do you think you could gain 50hp+ with only 6psi?
Old 03-17-2004, 05:55 PM
with a h22 how much $$ would mounting kits and other parts needed cost. also is a h22 easy to turbo?
Old 03-17-2004, 09:40 PM
Ricochet's Avatar
Banned
Re: Re: Re: Re: Re: GSR swap for a 99 civic ex/ d16 turbo
On the EX engine? I don't think, I know. Check out the article in Super Street of January or so where they put a base Eidelbach kit on one for it's dynocharts. My friend has a Greddy kit, but they add almost the same amount +- a couple hp maybe.
Check www.hasport.com for the mounts.
Easy to install, no. They are from a different chassis, a Prelude. The Integra and Civic are close enough to where you won't need much, but the H22 wiring harness is a bitch from what I hear and unless you plan on only going in a straight line, you're going to have some minor understeer and irregular tire wear without some beefed suspension. The inside of my tires wear quicker and I only went from a 1.6 sohc to a 1.6 dohc. Now imagine the 2.0 engine weighing things down. Turbocharging one would be just as hard/easy as boosting any other Honda engine..
Old 03-18-2004, 03:25 AM
Re: Re: Re: Re: Re: Re: GSR swap for a 99 civic ex/ d16 turbo
tru but i thik he'll still have to do his suspension if he jus turbo it jus to be on the safe side but if he goes with the turbo he still gonna have A MANUAL tranny! well if i had the money i would go with the gsr or look more into the h22a
mods: None yet...
Old 03-18-2004, 07:08 AM
liquidflame8 liquidflame8 is offline
no way a stock gsr puts down 165 whp and 125lb/ft of torque to the wheels. that's to the flywheel buddy
Old 03-18-2004, 12:03 PM
Ricochet's Avatar
Banned
Re: Re: Re: Re: Re: Re: Re: GSR swap for a 99 civic ex/ d16 turbo
you mean auto..
whoops sorry it's more like 150whp and 115wtq. My friend has one with i/h/e and he puts down 165whp.
Old 03-18-2004, 06:14 PM
Re: Re: Re: Re: Re: Re: Re: Re: GSR swap for a 99 civic ex/ d16 turbo
you mean auto...
lol yeah auto lol look at the time of that post that my excuse lol i was sleep typin
mods: None yet...
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
