Old 03-15-2004, 03:26 PM
hippychick_67 hippychick_67 is offline
Angry 97 Blazer Mystery leak
Antifreeze leaking from front of motor somewhere seems to only leak when I run the heater, Please Help!!
Old 03-16-2004, 08:46 PM
Alexxn 00 Si Alexxn 00 Si is offline
Try checking where the intake manifold bolts onto the heads at the front of the engine.....the seam right between the 4 front intake bolts...mine was leaking there and ran to the back of the engine but it could also leak to the front....I had my intake gasket replaced.
2005 Chevrolet Silverado 2500HD Ext cab
Old 03-17-2004, 06:32 AM
Re: 97 Blazer Mystery leak
Thank you very much, will check into that, I also heard it might be my water pump???
Old 03-17-2004, 10:45 AM
aleekat aleekat is offline
I had to replace the same gasket, but if it only does it when running the heater. Pop the hood, look against the firewall for 2 hoses about 1" around that run to the heater core. Follow them back towards the water pump. Maybe just the clamp needs replacing/tightening.
Old 03-17-2004, 04:06 PM
Gooseneck Gooseneck is offline
I agree with Aleekat, if it only leaks when heater is on than it is leaking somewhere from the coolant return from the heater core. coolant circulation is shut-off at this point when heater is off.
