I want to get a deeper transmission pan for my '99 Yukon with a 4L60-E transmission. Found one for a TH700R-4. Are these pans interchangeable? I want the added capacity plus a drain plug.
Thanks in advance! |
Trans pan
Hello,
I had the same thought on the trans pan since I had a pan for a 700R4. But after making a mess I found out that the pans are not the same. The 700R4 has the drain plug in the wrong place, unless you change your exhaust for it would drain all over it. Also the drop in the pan is on the wrong end for the added fluid. I am working with a 2002 but I would think they are the same. Hope that helps. |
