Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-15-2004, 01:18 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
blinker
ok my blinker went out on the side markers in the front. so i replaced them. well the left blinker bliinks when on but the right doesn't but all the bulbs are lit up. I thought it could be the blinker relay but the guy in wester auto insisted that it wasn't that. well if thats the case then whats going on?
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 03-17-2004, 01:00 PM
semisendiz semisendiz is offline
Re: blinker
Does your dash right turn indicator stay lit? May be a blown bulb, and only for the turnsignal, not both it and the drive light.
Old 03-20-2004, 08:44 AM
Re: blinker
dash lights work, I have a Question, does anyone know if each side of the blinker have its own relay, i dont suppose it does but just a thought? and could only one part of the relay go bad? if its only one relay
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 03-20-2004, 09:35 PM
dsatt12 dsatt12 is offline
I don't think it can. It's a really simple part that makes an intermittent circuit. It usually won't flash if the rest of the circuit is open though- usually with a burned out bulb being the culprit. I had to learn a bit about them while designing a replacement for the crappy wiring scheme in a '47 Ford pickup.
I just had a thought... does the hazard light switch use the same blinker relay? What happens if you turn that on?
Old 03-20-2004, 10:57 PM
GMkiller GMkiller is offline
Re: blinker
This is funny. My problem was that the blinker ligh onthe dash would stay on , sort of dimm like, and I would get a left turn signal message from the info panel w/ a nice chime to boot. I was ready to tear off the black panel on the driver side in search of this phantom relay. My muscle car friend popped the hood on the car unplugged the blinker in the headlamps and wiggled the wires and presto the dash light was out. I switched on the left turn signal and it worked fine. The best I could guess is that there is a short in the immediate wires near the bulb. The bulb could not be grounding correctly. I believe there is a copper color plate on the bottom of the lamp socket make sure that it is clean. Good Luck he save me a few dollars and some asprin.
Old 03-21-2004, 11:34 AM
Re: blinker
I did have the hazards on the other day and they worked fine.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
