Old 03-15-2004, 06:23 AM
cfarris cfarris is offline
2001 grand Am gauges- maybe, maybe not
I have a 2001 grand Am Se. First let me give you background. Installed new stereo with set of 15`s and amplifier in trunk. Started having starting problems, thought amp might be staying on all night so cut so cut off power to amp. Still had starting problems so put new battery in car and wired stereo where everything goes off when I turn off car.Thought all problems were solved. Wrong! Some days I get in the car and everything is fine.
If I star the car and all the lights come on like they are suppose to then I have all my gauges. Speedometer,RPM,fuel,etc... If they dont I know Im not going to have any of these things.At times after I drive a few minutes they will all flash and start working, other times they wont. I have drove home from work the last 3 nights with no speedometer or anything working. That makes me very nervous! Sorry post has so much info but thought background info might help. I have learned alot from these post. I hope someone can help me this time.
Thanks
Old 03-15-2004, 01:51 PM
urweak urweak is offline
Banned
Send a message via AIM to urweak
Re: 2001 grand Am gauges- maybe, maybe not
check your fuses, your alternater is probably being over powered. turn off your stereo and everything and just drive around without it on and see if that does anything.
Old 03-15-2004, 09:02 PM
If it was the fuses Nothing would work at all right?
Old 09-01-2004, 05:13 PM
ssono55 ssono55 is offline
cfarris - I own the same car and haven't made any modifications and all my gauges do the same thing. Usually they only stay off for about 2 min. and then come back on. I also would linke to knw how to fix th is
Old 09-02-2004, 11:21 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
you need a bcm (body control module), common problem on these cars. For your 2001, the gm part # is 12206799 if you have remote entry.
