Old 03-15-2004, 02:05 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
Angry fuel pump problems i think?
hi peps im a newbe. ive got a 1996 k1500 pickup and i need a fuel pump that wont bog down and etc...... and before the tune up at half tank if i punch down the gas it bogals down a tiny bit, but when i get lower in the tank it gets worest but as of a couple days ago when i did the tune up its now with a full tank of gas if i punch it, it then takes at least a full second to respond and i im now stuck in a hole of what should i do?
compontents ive added to my truck are:
aem brute force intake
gms mass flow sensor
modifid tb
accel extrem9000 sprak plug wires
accel ign. coil (made for my truck)
accel cap
accel rotor
denso irduim spark plugs
airaid tb spacer
hypertech powerstat 160
hypertech power tunin module (93 octane used)
flow master dual exhuast
auto speicalties underdrive pully (gator back belt used)
Old 03-15-2004, 06:42 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: fuel pump problems i think?
replace the fuel filter before you get too far ahead of your self. i would install a pressure gage and take it for a good drive before condeming the pump.
Old 03-15-2004, 11:28 AM
how do the pressure gages install? and the current fuel pump i have in there is rather new, its an ac delco
and what would the pressure gage do for me?
Old 03-15-2004, 12:06 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
It will tell ya how much pressure your pump is putting out. First thing you need to do is change the fuel filter like previously suggested. Chances are that could be what your problem is. They are only like $10 at Advanced Autoparts. I would also run some fuel injection cleaner through it too, becuase it could be dirty injectors causing your problem.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 03-16-2004, 02:30 AM
alrights ill put another filter on there to see if that solves the problem and what fuel injector cleaner would u recmond? i currently am runnin 2 bottles of lucas
Old 03-16-2004, 03:44 PM
I usually use STP, its in the black bottle. But for my last oil change I used Valvoline MaxLife Fuel System treatment. It came with the oil I bought so I figured I would try it.
**1966 Chevy II**
Old 03-19-2004, 01:17 AM
im still havin problems, dunno what to do
Old 03-19-2004, 04:38 AM
michelq michelq is offline
check your fuel pressure should be about 60 psi
Old 03-19-2004, 10:06 AM
if its not what do i need to do?
Old 03-19-2004, 11:09 AM
JWhite8055's Avatar
JWhite8055 JWhite8055 is offline
Did you reset the timing to go with all those goodies?
Old 03-19-2004, 12:22 PM
how would i reset the timin?
Old 03-19-2004, 11:40 PM
If your fuel pressure is not that, then your pump is going down.
**1966 Chevy II**
Old 03-20-2004, 02:45 AM
oh okz
Old 03-22-2004, 06:05 PM
i just need to know about what i can do for this freakin bog down its makin me mad as hell
Old 05-17-2004, 10:27 PM
cornfedmf cornfedmf is offline
change the spark plugs back to the expensive 8 dollar a piece ac delco double platinums. every other plug ive ran in mine did same as what yours is. i would recommend changing back to these original plugs.
