Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-14-2004, 11:41 PM
Louie Box Louie Box is offline
Angry Constant vibration inside car from engine
red
Old 10-19-2007, 04:45 PM
jencsman's Avatar
jencsman jencsman is offline
Re: Constant vibration inside car from engine
my wife used to have a saturn that did that. I think it turned out to be one of the mounting brackets for the engine was broken.
You can pick your friends. You can pick your nose.
You can pick your friends nose, but you can't wipe it under your friend's couch.
Old 10-20-2007, 05:46 PM
Davescort97 Davescort97 is offline
Escort guy
Ford put out a TSB about this. They have to change some of the transmission mounts and add some bushings. I know some Ford dealerships say nothing can be done about it. It's fairly expensive to get this done. I think in the $300 range. My 97 was doing the same thing. All of the mounts for the engine and tranny except for the top mount of the engine, are on the transmission. I put a board underneath my oil pan (aluminum) and jacked the motor up until the tranny was lifted about 1/2 an inch. Then I loosened and retightened all the mounts to 67 ft.lbs. It's called neutralizing the mounts. It worked for me.
Closed Thread
