Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-14-2004, 10:11 PM
vaporsynth vaporsynth is offline
94 SSEI, "performance shift" button does jack shit
I got a 94 bonneville and ive been reading up on this supercharged engine business that it comes with. I push the performance shift button by the Gear shift and it doesnt do anything but turn the light on. Could the supercharger be screwed up(which makes no sense from waht ive read) or can it be some weird electrical prblem, or what is going on? I want my supercharged engine to actually work!!! - thanks
Old 03-15-2004, 01:45 PM
92bonny 92bonny is offline
You probably won't notice too much, my sisters Trans Am has the button and all it does is firms the shifts a bit and holds the gears a bit longer. On a less powerful car you won't notice a huge difference, but a difference should be felt as the transmission shifts gears, not in power. Hopes this helps.
Old 03-18-2004, 07:24 PM
daman daman is offline
At W.O.T is the only diff you'll see, it delays the shift some in perf. setting. mine works good but i don't like winding it that tight
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 03-21-2004, 05:16 PM
BonneMeMn BonneMeMn is offline
Send a message via AIM to BonneMeMn Send a message via MSN to BonneMeMn
Re: 94 SSEI, "performance shift" button does jack shit
The Peform shift isn't really changing anything. You can get Bonneville's with it or without, if you get it with it, you have perform and normal. Perform shift is the same as the normal shifting program on cars without it. Think of the Normal Shift mode as a "dumbed down" shifting set.
Old 03-28-2004, 04:48 PM
Mpalze Mpalze is offline
Your supercharger works regardless of wether you've selected 'performance' or 'economy'.
