Old 03-14-2004, 09:31 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Question o/t: Need help from you photoshop guys!
I got photoshop CS and when I try to load it I get this message: memory could not be allocated for the activation process. Please close all applications and try again. Then you click ok and it shuts it off. What is it? I closed everything I could without shutting down the computer. I have 512 MB of memory so what the crap is up?
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 03-14-2004, 10:20 PM
travagliante's Avatar
travagliante travagliante is offline
Re: o/t: Need help from you photoshop guys!
try alt+ctrl+del and go to processes and end some ones that arent needed.
or also go to start>run>msconfig>click the start up tab>disable all from starting(they are all installed programs, not neccesary to run)
that should work hopefully
Old 03-14-2004, 11:54 PM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
If you are using windows XP check the virtual memory allocation, it is under system properties, advanced, performance settings, advanced, change
Give that a try
Evan
Old 03-15-2004, 01:44 PM
IntegraBoy2003's Avatar
IntegraBoy2003 IntegraBoy2003 is offline
what kind of Photoshop is the best to get?? I want to start to get into all that, since I am not that good with computers, I could use a little help please
http://www.retardsoftheday.cjb.net <<MY SITE, check it out, it is quite funny and Updated Every day
New York Yankees Join the asses, that rock the masses
David
Old 03-15-2004, 05:43 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Ctrl-Alt-Del and find out what processes are running before you attempt to run the Photoshop program and what percentage of the CPU they are using. Also, see how much physical and kernel memory is available (not used or non-paged). You may have some running processes eating up your resources such as Norton or McAfee.
Something else to think about is which hard drive / partition the program is installed. How much free space is left on your system drive and the drive/partition Photoshop is installed on.
I have 512mb of RAM in my PC and I have no issues running Photoshop 7 on Windows XP Pro. If the above doesn't seem to help, try reinstalling the program. Sometimes it's just a bad installation.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 03-18-2004, 11:01 PM
DigitalPhantom DigitalPhantom is offline
Re: Re: o/t: Need help from you photoshop guys!
Adobe Photoshop 7.0 is great, thats what I have and if you have the latest Adobe illustrator (i think 9.0 but dont quote me on that) it is really great too. Your looking to spend quite a bit of money buying those though....unless you can get it some other way (not inferencing anything here...)
Old 03-18-2004, 11:23 PM
Yeah, Adobe stuff it hella expensive. I could probably get a motor swap done on what it costs to buy a few Adobe products.
