Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 03-14-2004, 07:44 PM
Stratocaster Stratocaster is offline
Question 89 Continental Skipping-need some help
I've got a 89 Lincoln Continental, 3.8 V-6 Front wheel drive, My engine is skipping and I've tried everything, first of all, it's not head gaskets or burnt valves, or anything major like that. It started skipping just alittle and got worse over a period of a month. You can't even drive it now. When the engine is running it leaves a black smutty spot on the ground from the exhaust, (there is no smoking) and burnt like 2 gallons of gas in a matter of about 5 minutes of running in the driveway, and it backfires back through the throttle body only when you rev the engine real quick from an idle every so often, so the first thing I thought was flooding, so I tear it down to the injectors and pull them off (after replacing god knows how many sensors) I found that one injector doesn't have a little needle thingy sticking out of the tip and the rest do, could this injector be bad and constantly dumping fuel and causing the skipping problem??? Any help would be greatly appreciated.
57 Olds continental kit,I need some help/info. pontchief Ninety Eight 0 10-21-2006 05:07 PM
need some help resizing some pics for my sig twdz28 Camaro Discussions 2 09-02-2004 01:50 PM
Need some help findin some parts. slammina98blazer Blazer 5 03-02-2004 08:03 AM
Need some help from some one that can make custom PE parts. Jon MW Car Modeling 1 10-20-2003 10:33 AM
i need some help on some rims jays87 Tires and Wheels 10 05-07-2002 11:32 AM
