Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-14-2004, 06:38 PM
greddyteggy's Avatar
greddyteggy greddyteggy is offline
Send a message via AIM to greddyteggy
Vacuum sources on intake manifold
I just finished installing my greddy turbo/intercooler kits and tomorrow I'll be testing it out for the first time. My question is I wanted to know where all the vacuum lines are that I can tap into. I have the wastegate, blow off valve and boost gauge that need vacuum sources. I don't want to tap into the same line for everything like the fuel pressure regulator line but that's the only one that I know of and the only one people suggest to me.
Old 03-14-2004, 10:18 PM
quick95civic quick95civic is offline
for the boost gauge and the blow off valve the vaccum line to the stock fuel pressure regulator will be fine, just get some "T" fittings and use those. If you have the greddy kit then the turbo should have an integral waste gate that hooks up directly to the pressurized side of the compressor housing. Most wastegates need to see boost not vaccum.
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 05:22 PM
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
vacuum lines...intake manifold anothercrx '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-17-2004 02:26 AM
