Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-14-2004, 06:14 PM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
DSM Injector install questions
Trying to install DSM 450 injectors,
First question - You have to make the rubber seal for the O rings bigger, do you have to make the other hard plastic thing under the seal bigger or is that a stop for the injectors?
Second question - I was told that I need a S-AFC or Hondata or something to run these, Now Do I absolutly need one? I just bought a new 12:1 FMU yesturday to replace my 10:1 and I dont want to have to replace that since its about half the price of a S-AFC and a day old. But I was also told that it would run fine under throttle, just it would idle wierd.
Third question - Can I use wiring clips from a older Civic (Style with the reistor box) for these injectors?
BTW, I am using 10 ohm; 10 watt resistors.
Kyle
[url=http://www.automotiveforums.com/vbulletin/showthread.php?
1995 Honda Civic EX
-Integra B18B1 LS engine
-Turbocharged
-Rear disk conversion
-Many mods
Cheak out my civic (cardomain)
Easly got 10k into this car with everything and it still looks like a POS
DSM Injector questions IntegraB18LS Let's get Technical! 1 03-24-2004 02:18 PM
Spider Injector Installation Question Ia_Venom Jimmy 3 01-19-2004 03:25 PM
DSM injectors (Mitsubishi Galant VR4?) ZORT Forced Induction 0 06-24-2002 11:56 AM
dsm injectors on b series motor thurman548 Engineering/ Technical 1 04-05-2002 01:01 PM
DSM injectors on honda b-series motor thurman548 Engine, Transmission and Drivetrain 0 03-30-2002 06:53 AM
