Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-14-2004, 04:44 PM
thedreadedpenguin thedreadedpenguin is offline
Question tach
I have a 93 crown victoria police interceptor and i would like to install a tach in her. if any one knows the best way too go about this some help will be greatly appriciated.
Old 03-14-2004, 10:57 PM
ModMech's Avatar
ModMech ModMech is offline
Re: tach
Lemme find my wiring diagrams...it can be done by splicing ONE wire, I just need to find which one.
Old 03-16-2004, 06:58 PM
Re: tach
that would be greatly appreciated. i have a 3 1/2 sunpro tach, it has a tach, ignition, a light wire and ground wires. would this work ok? i just didnt know where exactly the tach and ignition wires should go.or do i just need the tach wire?
Old 03-20-2004, 06:25 PM
ModMech's Avatar
Re: tach
Ok, according to my manual, the SECOND wire from the LEFT end with the "tab" on it (looking into the connector with the lock tab facing you), is the TACH driver wire. It appears as though this would be the SECOND wire from the front (connector tab facing the fender).
Old 03-20-2004, 09:58 PM
Re: tach
this is the conector coming from the pcm?
Old 03-21-2004, 10:37 AM
ModMech's Avatar
Re: tach
No, it's the connector for the EDIS (Electronic Distributorless Ignition System) module that is bolted to the LEFT inner fender, just behind the relay box. It should say EDISS on a white tag on the top of the module.
Oh, yes you need a Ignition switched power supply, (you can get that in the fuse panel) a ground, and the light is optional.
1995 F150 W/o tach into one with tach nascarjr311 F Series 1 10-08-2007 07:03 PM
non tach to tach cluster install veedubmechanic Corolla/Matrix/Voltz 10 11-02-2006 04:52 PM
93 tach cluster in to non tach now dont charge gbic1 F Series 0 01-07-2006 10:42 PM
4cyl tach to 6cyl tach Tafnar 4Runner/GX470 0 06-27-2004 03:00 PM
4cyl tach to 6cyl tach Tafnar Pick-Up 0 06-27-2004 02:55 PM
