Old 03-14-2004, 12:01 PM
TOENY1967 TOENY1967 is offline
Fuel Injector Voltage Question
I NEED SOME HELP GUYS/GIRLS...
BOTH FUEL INJECTORS GET POWER TO THEM,, WE HAVE SWITCHED THE WIRE HARNESS, ONE SIDE WORKS PERFECT AS FAR AS THE INJECTOR SPRAYING, THE OTHER DOES NOT..
BY READING ON HERE I AM THINKING ITS THE 5 VOLT GROUND DEAL....
WHERE IS THIS 5 VOLT GROUND, AND /OR CAN I SPLICE OFF THE GOOD SIDE ??
THANKS..
IF I AM NOT BEING CLEAR WITH THIS LET ME KNOW OR EMAIL ME PERSONALLY AT [email protected]
BY THE WAY ITS A 91 BLAZER 6 CYL4.3
Old 03-14-2004, 07:41 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Fuel Injector Voltage Question
check the wiring. the injectors are fired by a ground pulse to one of the wires. i'm guessing this wire is open somewhere between the injector and the computer if you tear into the harness you'll probably find an open somewhere. check the connector at the computer too if you have continuity for all the wires from the computer to the injectors the computer is bad. if you get to the computer without finding an open try giving the computer a good smack most of the time this temporarily fixes them. good luck
Old 03-15-2004, 12:31 AM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
THANKS..
plug in a noid light first and check for flash before we blame the ECM or quaddrivers
Old 03-15-2004, 11:59 AM
Re: Re: Fuel Injector Voltage Question
WE KNOW WE ARE GETTING POWER, AT LEAST THE 12 VOLTS...
YOU THINK THE ECM, MIGHT BE IT? IS IT COMMON?
Old 03-15-2004, 06:04 PM
Re: Re: Re: Fuel Injector Voltage Question
the injectors are energized whenever the key is turned on. What the ecm does is supply a ground in order to fire them. the "'noid light" is a little tool that will flash each time the ECM supplies a ground, its an easy way to test for at least the wiring being intact.
if the harness fires, but the injector does not, then you have a problem with the injector itself or fuel lines leading to it
Old 03-16-2004, 12:08 AM
Re: Re: Re: Re: Fuel Injector Voltage Question
ok, now you got me.... what exactly is a noid light your referring to, is it just a voltage tester?
Old 03-16-2004, 04:28 AM
Re: Re: Re: Re: Re: Fuel Injector Voltage Question
no, it is a little plastic doohickey with a high intensity LED in it and a resistor and a plug that will fit the harness, there are about 6 common ones, you can buy them as a set (mac tool makes the set I have) but you can 'rent' them individually from autozone
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 01:06 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
Fuel Injector Cleaner Question DistanceGuy1 Taurus | Taurus Wagon 7 10-25-2007 09:39 PM
Fuel Injector Cleaner question kingrichard336 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 09-11-2005 01:39 AM
fuel injector replacement question drock59 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 11-10-2004 12:05 AM
