Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-14-2004, 02:12 AM
moleodonuts's Avatar
moleodonuts moleodonuts is offline
Send a message via AIM to moleodonuts
Unhappy help: lots of vacuum, really rich
So I've got a new toy: a JR supercharged b16a. Problem being, I'm scared to push it as it stands. According to my AF gauge, its running super rich through out the powerband, I mean that thing is drillled against the maximum richness. Also, my boost gauge is reading around 20 psi vacuum at idle and not until I get up toward the 4000 rpm mark do I really make it past 0 psi.
BTW, I'm running a holley fuel pump, a JR FPR (10:1 I think?), and have done no A/F tuning, let alone have a way of controlling my A/F ratios as of yet. I have an AEM 1:1 FPR and dsm 450cc injectors at my disposaland I'm supposed to be hitting 9 psi with my pulleys from what JR says
My questions are:
1) Do my boost levels seem even remotely reasonable for a correct set-up?
2) Should I worry about how lean I'm running until I can get a cheap-o VAFC or something like that? Will the injectors or the FPR help that? (seems like the injectors alone would just make things worse, and I've heard that lower fuel pressure = higher fuel delivery... so I was worried about that)
3) Do you think this engine set-up seems stable enough that I could push it from time to time and stay daily drivable (as it stands I've never brought it within 1000 rpms of redline and have never gone beyond about 3/4 throttle)?
95 Civic Si - Thunder Grey Exterior
-Performance: B16A, JR supercharger @ 9 psi, JR FPR, Tokico 5-wy Adjustable Shocks, Eibach springs, F/R strut and swap bars
-Audio: Alpine 9815, 3-way component Pheonix Gold speakers
Car is running really, really, really rich. yhandor Cavalier Problem Diagnosis 7 09-02-2007 08:07 AM
88 Bronco 2, low vacuum, runs rich. ghostman916 Bronco 1 08-19-2005 12:16 AM
91 Talon running really rich!! nates6969 Off-Topic 11 07-15-2004 09:35 PM
88 running really rich manyodas88 Camry/Camry Hybrid/Vista 8 05-02-2004 01:32 AM
Engine running really rich. DtayOJ Engineering/ Technical 1 10-21-2003 08:07 AM
