Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 03-14-2004, 02:10 AM
beckgts beckgts is offline
90 celica problems.......
i have a 90 celica gt. i have a very odd problem with the car. when i get up to about 5000 rpm the car cuts out, but its not like a stall.it is almost like if i had the car in 2nd gear at 50 mph and let off the gas. you know how a car will jerk when you do that. however it does not do this all of the time. i cleaned the injectors and fuel rail. and i replaced the fuel filter. any suggestions on what my problem might be would be helpful.
Old 03-15-2004, 10:10 AM
Sypherz28 Sypherz28 is offline
Send a message via AIM to Sypherz28 Send a message via Yahoo to Sypherz28
Re: 90 celica problems.......
I must admit that is kinda odd.. What does the car redline at?
1987 Mazda B2200
Old 03-16-2004, 04:41 AM
3rdWrldRcr 3rdWrldRcr is offline
Sounds like it might be time for a rebuild. If the car has been driven hard or has seen a lot of races and has about 150k miles on it you've hit it's life expectancy. If you're burning oil you might just need a valve job. Either of these could coase a jerking or cutting off of a heavily used motor.
Rabbit
Old 03-16-2004, 11:54 AM
Yes I have to agree with the rebuild idea.. That should solve your problem definately, and also in doing so your get back so much more of your performance.. Since you know it happens at 5000 RPM's then you are definately driving it hard..
1987 Mazda B2200
Old 03-16-2004, 08:11 PM
skaterblader23 skaterblader23 is offline
Recently my 1990 Celica ST began losing power...i dont mean small amounts, i mean like i could feel 30-50HP being lost instantly...it was even having trouble in 2nd gear on flat roads.....
My dad, my uncle, and myself began fixing it...we found that the ST and GT versions between the years 1990-1993 have issues with losing the power of a cylinder or two....we had to change the spark plugs, and distributor cap.....CHANGE THE DISTRIBUTOR CAP....it was mine and a few others that i know problems...this cap seems to go bad every 3-5 years....check it before you do anything else
Old 03-18-2004, 06:57 PM
i know that i dont need a rebuild because the car runs like new unless i get it up to 5k. it doesnt burn any oil. i have new plugs,wires, cap and rotar. it just feels like the computer is shutting down the fuel pump. but it shouldnt do that until i red line right? it red lines at 62k.could it have anything to do with a dirty intake manifold? im stumped. any other suggestions????
Old 03-18-2004, 07:21 PM
Well the computer issue is a possibility, but it should let you redline it yes.. You might want to try getting your fuel system professionally cleaned (even if it's not specifically the problem, it doesn't cost that much at all anyway) and if you have never changed your fuel filter you should go ahead and do that too (another low cost item, should be changed every 30,000 miles or so).. Intake manifold I wouldn't think could do somthing that specific, cause if it's dirt getting in then you would see it happening more often then 5k on your RPM's.. If you haven't already reset the computer, just disconnect your negative battery cable for at least 30 seconds, then try running your car again..
1987 Mazda B2200
Old 03-20-2004, 01:35 AM
i have one more problem. i raced an accord and he handed my ass to me. this didnt seem right because i have beat him before. so i went home and poped my hood, and my #3 plug wire was half out of the hole. this isnt the first time this has happened. any ideas on what it could be????
Old 03-20-2004, 04:32 PM
If the plug wire isnt holding then I would change the wire.. Usually it can be a bad clip on the wire.. Also pop open your hood with the engine running in the dark and see if there are any sparks comming off of the plug wires, if so change them all anyways..
1987 Mazda B2200
Old 03-21-2004, 01:09 AM
ok i replaced the plugs and wires. but the problem was still there. so i gave up and figured i would worry about it later. i took my stock air box of and replaced it with a cold air intake and now the problem is gone. funny how things work out..... its almost as if it wasnt getting enough air at high rpms. witch in turn wouldnt let my plugs fire, so the car didnt run. either way im just happy it runs good.
Old 03-21-2004, 01:12 AM
hehe your car is like "FUCK YOU DONT TO GIVE ME AIR, THEN I WONT FIRE....TAKE YOUR FUCKING SPARK PLUG!"
Old 03-21-2004, 01:54 AM
jaggedyer jaggedyer is offline
Dude the problem was most likely a clogged up air filter all along, thats why it choked it at high RPMs. Quite contrary to marketting crap the stock intakes are actually pretty frickin good if you use a good clean filter. There are obviously small gains to those cold air intakes (not 'cold air', toyota already takes 'cold air' from the wheelwell and front) but its pretty insignificant enless your engine already is producing so much HP that becomes a bottleneck.
Old 03-21-2004, 11:07 AM
I still say if your hooking up your car that you do the professional fuel system clean, my friend had it done and the performance difference was crazy.. Good job on the fix by the way
1987 Mazda B2200
Old 03-22-2004, 01:54 AM
hey i got you guys to thank because all that info had me trying to fix everything in sight just to make it run good. then that poped in my head. THANK YOU!!!!
not a celica problem but.. C-Stylez Celica 1 10-06-2005 02:58 PM
1988 celica problems tybee Celica 0 07-28-2005 09:36 PM
86 celica problems Redneck12095 Celica 1 05-03-2005 01:30 PM
Celica problems cdk001 Celica 1 01-20-2005 11:54 AM
1984 celica problem please help civic_racing_01 Celica 1 09-26-2004 05:43 PM
