Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-13-2004, 06:16 PM
torkd torkd is offline
94 camry rear lights not workin when backin up
i have a 94 camry that decides to not turn on backing up lights when the car is in reverse. The dash light is fine on P but when i shift to R, usually the R light (on dash) doesn't come on when i have just started the car from cold (which means that the reverse lights also do not turn on).
When the R light on the dash is on, my rear lights come on. When my R light is out, my rear lights are out.
The brake lights work perfectly everytime tho.
Also, sometimes the D doesn't come on when I put it in drive.
usually after i've driven for a while, and I try to put it in R again, it will work. Sometimes, I have to nudge the shifter a little bit to get the R light to light up. I have already taken it into a shop to get it fixed, but then it broke again, and so I want to try to fix it myself.
i'm pretty sure it's a wiring problem.
thanks for any help and/or input!!
Matt
Old 03-14-2004, 05:33 PM
Joe W Joe W is offline
Re: 94 camry rear lights not workin when backin up
It does sound like a wiring problem.The first place to look is the hinge area in the trunk.Try to jiggle the wires while observing the lights.
Old 03-14-2004, 11:58 PM
phisigbrotha phisigbrotha is offline
wiring or the cable needs to be adjusted. im just about to go adjust mine now. it does the same thing almost. i have to play with the selector to get them to come on. ill let ya know if it worked.
Old 03-15-2004, 03:19 AM
ToyotaTech ToyotaTech is offline
U need a safety netural switch it is going bad! it is on the trans where the cable goes down to the trans! I have replaced a buch of them in my time
Old 03-16-2004, 12:28 PM
sweeeeet. thanks for your suggestions, i hope one of them fixes my problem :-).
i'm really new to car maintenance, but i'll definitely let yall know how it turns out
