Old 03-13-2004, 04:16 PM
bp751 bp751 is offline
Send a message via AIM to bp751 Send a message via Yahoo to bp751
removal of oil cooler lines
Okay I have a 1997 blazer 4wd. So as with other common problems my oil cooler lines are leaking. I've read the other posts but I'm still confused. how do you remove the oil cooler lines from the fittings or do you have to remove the fitting along with the lines. Any help would be much appreciated.
Old 03-16-2004, 08:30 AM
MGoBlue102 MGoBlue102 is offline
Re: removal of oil cooler lines
Yea, the fittings are usually what leaks. The ones that enter the radiator. The fittings come on the form fitted hoses, if your gonna replace yourself, simply drain the oil, disconnect the leaking line, connect the new one and refill. The fittings are part of the hose itself.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
