Old 03-13-2004, 03:56 PM
petiedawgs petiedawgs is offline
High pitched screeching, in Engine bay
Hi everyone,
I have this high pitch squeaking sound in my engine area, cannot locate the exact position of the sound. Checked the oil and the oil is fine. Any suggestions on where else a high pitched screech will come from. Also the screech gets louder when i hit the throttle.
P.S. I was thinking maybe the water pump was doing it???
Old 03-13-2004, 03:58 PM
Sorry i have a 2.8L V6 RS Camaro
Old 03-13-2004, 04:53 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
belt, water pump, Alt, bearings. Does you belt looked like it is slipping or burned?
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 03-13-2004, 08:25 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: High pitched screeching, in Engine bay
get a 3/4in diameter rubber hose, about 3-4 feet long, hold on end to your ear, and then move the other end from one pully to the other in the engine bay, when the sound gets the loudest, youve found the problem spot. i would say that a bearing on one of the pullies is shot.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 03-14-2004, 02:47 PM
thanks im gonna look at those things and try out the hose.
Old 03-16-2004, 11:05 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Hey my friend had a v6 camaro (96) and it made a loud sound like that too and it got louder as he got on it. When he got it fixed the mechanic said it was his a/c. His car smoked even after he "fixed it" so i don't know about the smoke.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 03-16-2004, 11:07 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
pretty much established that its more than likely a pulley bearing, just a matter of determining which one...
Old 03-16-2004, 11:32 PM
caw333 caw333 is offline
Well an owl could of taken up residence under the hood and every time you crank the car he gets ticked off. But Its definitley got something to do with the belt slipping. Try taking the belt off and turning the accessories buy hand to see if you can feel any kind of a bind. also while you have the belt off crank it for a second and see if the noise goes away. If it does than you can continue to narrow it down. My A/C clutch went out on mine and the bearings made a bad grinding noise for a month before it finnaly lock up. This had the belt from time to time slipping and making a high pitched screeching. It also costed $621 to have all the A/C stuff replaced.
