Old 01-06-2002, 01:05 AM
vtecattack vtecattack is offline
Send a message via AIM to vtecattack
smoke???
I have a 92hb with a b18c swap. I have the Teg exhaust with no muffler on yet. Recently I have notice that when I start the car in the morning alot of black/carbon looking moisture is all over the ground. What really worries me is that when I accelerate and VTEC kicks in a puff of black/brownish smoke blows out the exhaust. Has anyone had similar problems like that or is there nothing to worry about? Also there is like a metallic dust all over the back of my car, like from the cat??
Old 01-06-2002, 02:52 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
What ECU are you running? It sounds like its running a little rich.
And isn't VERY loud with out a Muffler?
Old 01-06-2002, 11:32 PM
ecu
I am running a rechipped 92 Si ecu and harness. The stock exhaust has a resonator so its not that loud. If it is running rich what can I check for? Thanks for the help.
Old 01-07-2002, 07:03 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
Yeah it sound like it is running rich. How is it Running? Does it run rough or anything? Also see if your exhaust is a blue-ish color. If it is then you are burning oil.
Old 01-07-2002, 08:49 PM
91zc 91zc is offline
Black carbon moisture sounds like you are running a rich condition like the other guys said. I was having the same problem with my ZC because of a shitty O2 sensor. One way to fix your problem is to invest in a fuel computer to lean out the fuel in your mixture.
91 civic 4dr
b16a
14.8@94
Old 01-07-2002, 09:05 PM
Buying a fuel computer might not help that well because if your o2 sensor is bad then it be "sluggish" and won't have the right reading no matter what. It is suppose to read rich, lean, rich, lean in a constant manner and it being "sluggish" will make it read rich and stay there for a while then change over. If you hook it up to a computer you will see what I mean. Also it could be your MAP sensor. It measures the amount of pressure in your intake and will tell the computer how much fuel to give it. A fualty map sensor will not show any signs unless under a load. So if your car idles good and crappy under accel then it could be your map sensor. Any other drivibilty information could help.
Old 01-07-2002, 09:18 PM
True, but usually with a faulty O2 sensor, or a faulty map sensor the ecu with throw a code.
91 civic 4dr
b16a
14.8@94
Old 01-07-2002, 09:25 PM
Thats very true but i had cases where a bad MAP sensor wouldn't throw a TC. I'm not saying thats the case here...
Old 01-07-2002, 11:30 PM
smoke??
The engine runs great at idle and at higher rpms. It just blows out some smoke or dust at high rpms, I notice it when vtec kicks in. Also it smells like hell when the cat heats up!! And there is a brown/metallic dust all over the back of the car?? Could the cat be bad? No codes have come up either... Thanks.
Old 01-08-2002, 02:03 AM
pvang31019 pvang31019 is offline
yes, the cat is clogging up(the smell) and the honey comb shit is falling apart(the metallic dust)...time to gut the fucker
