Old 03-13-2004, 07:16 AM
lly1982 lly1982 is offline
good na setup on b16a
i've got a friend who will be goin over to the states next month and gonna get him to buy me some stuff, i was thinkin of skunk stage 1 cams with the valves,springs, retainers. what do you guys think of skunk? are they worth the money? or shall i buy some other alternative? what else would you guys recommend me changing?
Old 03-13-2004, 07:42 AM
SiZ's Avatar
SiZ SiZ is offline
Re: good na setup on b16a
If you're only getting stage 1 cam why are you replacing the springs and retainers? Also, why are you only getting a stage 1 cam? Do they even make much power over the super-cheap ITR or CTR cams?
If you get some cams, look into a new intake manifold. 1st gen B16s have tiny IMs..
"The nympho of info, I'm fuckin' what ya heard"
Old 03-13-2004, 09:46 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
If your getting the valves, springs and retainers, might as well go with some stage 2 cams...
Also, a ITR/Skunk2 Intake manifold would help open up the breathing on the 1.6
Julian
Old 03-13-2004, 08:41 PM
but i read on their website that stage two gives you rough idling, what kind of setup would you recommend? not being too expensive.
Old 03-13-2004, 09:12 PM
kapt kapt is offline
Send a message via AIM to kapt
i have stage2's in my b16 and the idle isnt bad at all. my friend has stage3's and his idle isnt even that rough. sometimes u cam out at idle and the ecu just catches the motor before it falls on its face.
but neway, sounds like ur doin something similar to what i am, heres my setup:
b16, stage2's, springs/retainers, closed deck block, 3 way port/polish, 9lb flywheel, stage2 clutch, 50 shot dry nos, obd1 conversion --> hondata. srp 10.5 cr pistons, forged h-beams.
i should be good for ~200 hp before the nitrous.
good luck with ur n/a build.
Buildin up the b16 before i drop it in the CRX!!!
New 1989 CRX - i/h/e ;o
(retired)1990 Honda Civic DX HB - JDM b16a w/ hasport motor mounts, DC Sports Intake, APC short throw shifter, banzai motorsports muffler, neuspeed 2.5 inch drop pro springs, tokico blue shock/ struts, polyurethane energy suspension, dc sports rear strut tower brace, toucan front strut tower brace, JDM CRX rotors/calipers, Venom high-flow fuel pump, AEM fuel pressure regulator.
http://www.geocities.com/kaptr1d
Old 03-14-2004, 02:53 PM
where is the best place to look for the type r parts?
