Old 03-12-2004, 11:00 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
CTR pistons?
OK, I have been thinkin about changing my pistons to ctr pistons to boost the comp a bit, anyway Whenever I find them they are always listed as being able to fit any B16 or B18, ny question is will they fit my B17? I think that all that is different is the stroke. i think the bore is like 205 mm or something simmilar to that. so anyway if I pick up a set of genuine or aftermarket ctr pistons will they fit into my block and bolt onto stock length rods without clearence problems.
Also whats the main differences between my B17 block and similar year B blocks? I mean it is a bitch to find parts for this engine, so i'm wondering if it really matters I mean if I buy a header for a B18A will it bolt onto my B17A? or cams? will cams for other B's fit my B? just curious cus I finally have a bit of money to spare and i can't find shit for the B17
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 03-13-2004, 07:27 PM
knorwj's Avatar
sorry for the bump but I know that some of you guys know this.
Old:
New:
Newer:
Old 03-14-2004, 12:29 AM
darkerdayz darkerdayz is offline
Send a message via AIM to darkerdayz Send a message via MSN to darkerdayz Send a message via Yahoo to darkerdayz
Re: CTR pistons?
ok, first off, i i'm not sure, but i think that your b17 block might be more similar w/ the b18 block (seeing as it is comming out of an integra). secondly, how do you figure that changing the cams will raise compression ratios? i've never heard of that happening before, but please correct me if i'm wrong.
friends don't let friends drive stock
Old 03-14-2004, 03:53 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: CTR pistons?
If you don't know don't post...
The B17A1 is a B16A, same block, same head, same everything , except the stroke.
B17A1
1678cc
160hp@7600
117lbs-ft@7000
10.0:1 CR
81mm bore
81.4mm stroke
B16A3
1595cc
160hp@7600
111lbs-ft@7000
10.4:1 CR
81mm bore
77.4 stroke
Old 03-14-2004, 02:19 PM
knorwj's Avatar
first off who said anything about cams?????
second off thanks again jcrx, once again you are the man.
Old:
New:
Newer:
Ctr pistons..how can u tell? mellowboy Engineering/ Technical 2 03-25-2002 09:54 PM
CTR Pistons in B16a -- Install Si2000 Vtec Engineering/ Technical 1 02-03-2002 09:05 PM
CTR Pistons - Install and Compression Question Si2000 Vtec '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 02-03-2002 03:29 PM
ITR or CTR pistons in my b18c1? SFF900 Engineering/ Technical 0 02-02-2002 01:53 PM
CTR pistons in my b18c1 SFF900 Engineering/ Technical 2 01-31-2002 05:47 PM
