Old 03-12-2004, 10:37 PM
peach peach is offline
Angry replaced starter/engaging without key
HELP - We replaced the starter in our 99 tahoe but when we reconnect the negative battery cable the starter engages without the key - it started the engine on it's own. Any ideas or suggestions?? This is the second re-man starter in just a few hours. Connection is correct.
Old 03-13-2004, 12:18 AM
Daver84 Daver84 is offline
Re: replaced starter/engaging without key
Are you saying the engine actually started or was just turning over constantly? If it's just turning constantly you may have a faulty starter relay that does not disengage. Check for 12 volts at the small wire on the starter which would indicate a stuck relay. Replace the relay. If your engine actually runs without a key you have serious wiring problems.
Old 03-13-2004, 01:38 PM
michelq michelq is offline
make sure battary cable is not tuching soliniod wire when you instaled the starter,it is commen mistake
Old 03-13-2004, 01:39 PM
rooster_01 rooster_01 is offline
Happened to me once too
Check the connections, If it is starting when you connect the batt. you have power getting to the starter. I gurantee you have crushed a wire or have 2 wires touching. Check it out, I know it can be frustrating.
Replace starter without removing exhaust Sprint45 Trooper | SLX | Bighorn | Wizard 9 11-05-2015 09:17 PM
Unknown alarm system replacing remote Football42008 Engineering/ Technical 6 01-17-2010 10:44 PM
replaced starter 98 camry won't start with key bmpeak Camry/Camry Hybrid/Vista 2 07-28-2005 10:57 PM
