Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 01-06-2002, 12:15 AM
R324EVA R324EVA is offline
Air horns???
Could someone tell me wether I need to fit the relay supplied with the airhorn set or can you just hook up the horn wire to the +'ve on the compressor and earth the other side.
Old 01-06-2002, 06:08 PM
TINDUCK RACING TINDUCK RACING is offline
Send a message via AIM to TINDUCK RACING
Hi dude.....
........ALWAYS fit the relay...it's not a big job, and worth doing. The air horns pull a much greater current than the factory horn,and you risk welding your horn push contacts together if you wire direct....
hope this helps,
Jon.
Where's the Forums?????
Old 01-07-2002, 02:09 PM
Cheers Jon, I knew someone out there would be able to enlighten me as to why the relay was included.
Old 06-08-2002, 09:48 AM
Cheechman7 Cheechman7 is offline
Can someone write out the steps in installing air horns? i have everything i need however do not know how to install them...id like to have a relay to switch from stock to air horns and be able to use my steering wheel for both sets of horns.
