Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 03-12-2004, 08:39 PM
bfr57 bfr57 is offline
99 Neon code clearing??
Need help on clearing old trouble code from computer. Had a code 43. Changed plugs/wires and now running great, firing on all cylinders, but service light still on and saying 43. I've disconnected the battery thinking that would clear it, but it didn't. How do you get that code out?
Old 03-12-2004, 10:04 PM
carguyinok's Avatar
carguyinok carguyinok is offline
Re: 99 Neon code clearing??
Disconnect the Batt. and let it sit for like 10 minn. Then hook it back up.
Rules of the game fast,good, cheap pick any 2
fast + good = not cheap
fast +cheap = not good
good + cheap = not fast
Because the water has no speed limits
Old 03-14-2004, 01:04 AM
NeonStyl NeonStyl is offline
Send a message via AIM to NeonStyl
Exactly what Inok said . Some people just remove the negative terminal from the battery and let it sit for a couple minutes. You may still get a code 12, however this is normal and simply means that the battery has been disconnected within the last 50 key-on cycles... DuH! hehe. That code 12 atleast will go away by itself and is nothing to worry about.
L8R,
~NeonStyl
- www.neonspeed.com -
Old 11-23-2006, 10:55 AM
96Tapout 96Tapout is offline
pull the fuel pump fuse out of the pcm for about ten min, then u dont get code 12 and u wont need to reset ur clock
Old 11-25-2006, 02:56 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
LOL...did you not realize the original post was over 2 years old???
2003 Dodge SRT-4
Old 11-26-2006, 12:09 AM
Ya, but I was reading through old posts to find possible answers to my question so if anybody went back to read about code clearing thered be new info
Old 11-26-2006, 03:22 PM
Its in the 1st Gen FAQ's
2003 Dodge SRT-4
Old 11-27-2006, 07:51 AM
fair enough lol.
95 monte code clearing frank714 Monte Carlo 1 04-06-2006 08:28 AM
97 Neon Code 35 Radiator Fan Louseman 1st Gen 95-99 1 01-04-2004 10:27 AM
2000 Neon- Code PO455 ennoct 2nd Gen 00-05 0 12-25-2003 08:09 PM
1995 Neon - Code 43 Mike Poirier 1st Gen 95-99 3 10-19-2003 04:36 PM
