Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-12-2004, 05:54 PM
hellzfirefly hellzfirefly is offline
Send a message via AIM to hellzfirefly
Question Help find a part?
A friend of mine has a 2000 Dodge Neon that needs a new tensioner pulley. The mechanic says that it's a part on neons that commonly breaks down, and the part can only be ordered from the dealership. We're not quite familiar with auto parts and where to get them, but is there some other place you can commonly get parts like this?
Old 03-14-2004, 01:13 AM
NeonStyl NeonStyl is offline
Send a message via AIM to NeonStyl
Re: Help find a part?
Unfortunately, some parts are dealer-only . However, to make sure you can always simply just call up some of the local auto-parts stores in your areas (i.e. AutoZone, PepBoys, NAPA, etc.) and ask for a tensioner pulley for a 2000 Dodge Neon.
L8R,
~NeonStyl
- www.neonspeed.com -
Old 03-17-2004, 10:33 AM
drag1320neon's Avatar
drag1320neon drag1320neon is offline
Send a message via Yahoo to drag1320neon
thats crap, ive heard of the timing belt tensioner breaking, but not the pulley
Old 10-09-2005, 10:05 PM
ebailiff ebailiff is offline
If you live in Los Angeles, call Auto Parts Unlimited.
Old 10-10-2005, 05:00 PM
Fractured1 Fractured1 is offline
or you can try ROCKAUTO.COM
Old 10-12-2005, 02:36 AM
sheetmagnet sheetmagnet is offline
Send a message via Yahoo to sheetmagnet
Re: Re: Help find a part?
Um, I had a tensioner pulley break (shatter, more like it) while I was on the E-way in my '98 Intrepid... took the bearing, spacer, and retainer with it; melted the belt and snapped it, and had enough heat to bend the pin that it rides on. Anything is possible.
Old 10-12-2005, 03:07 AM
Re: Re: Re: Help find a part?
When replacing a snapped timing belt on a '97 Neon SOHC, I bought a timing belt kit that included the tensioner pulley. The old pulley had play in the bearings compared to the new one. The tensioner still worked fine, but I had to play with the adjustment a little to get right. It required about 1 ft/lb more torque than the book said; could be my torque wrench. Anyone had similar experiences with the tensioner?
