Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 03-12-2004, 04:34 PM
pdieni pdieni is offline
Unhappy Altima fuel fill problem
Having a problem with filling the gas tank on a 1998 Nissan Altima. Had the car serviced at a garage and it was fixed, an evap valve mechanism of some kind in the tank that opens and closes. The problem came back a short time later and the garage says it will probably keep coming back unless we replace other parts including getting a new tank from a newer Altima. I guess the early 1998 Altimas are cursed with this problem? Is anyone else experiencing this and if so, has anyone found a simpler solution? The garage said the problem had to do with this evap valve mechanism and the shape of the tank.?.? This problem is very annoying, it takes 15 minutes or so to fill the tank, if you go faster than a trickle, the fuel sprays back at you! Any ideas would be appreciated.
Old 06-24-2004, 09:08 PM
habenero2002 habenero2002 is offline
Send a message via Yahoo to habenero2002
Re: Altima fuel fill problem
i have seen one of the evap lines become pluged on this car that causes this problem. Was this a nissan dealer that worked on your car?
Old 11-28-2004, 03:16 PM
shesparkles shesparkles is offline
Question
Hi,
I'm having the same problem with my 98' Altima. So have you figured out what the problem is?
Old 05-14-2005, 01:14 PM
y2kpa2's Avatar
y2kpa2 y2kpa2 is offline
Village Idiot
I Would Check The vent line if it is blocked you will get that i would think
