Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 03-12-2004, 05:24 PM
acid55 acid55 is offline
Blinker Problems - Honda Shadow 750
I got a used Shadow 750, and I'm having blinker problems.
The front lights have two filaments, and the running lights in them work normally.
When I put on the left blinker, the front-left running light goes out,
and the blinker filament does not blink. The rear blinker does not blink either.
Same thing in reverse for when the right blinker is on.
I've checked the switch box on the handlebars, and everything seems to be the same as it is in the service manual.
I'm hoping that it is a simple fix...
Does anyone know how to fix the problem?
Thanks.
-Frank
Old 03-12-2004, 07:33 PM
EGcivicSi's Avatar
EGcivicSi EGcivicSi is offline
Re: Blinker Problems - Honda Shadow 750
Check your fuses? Check your relays?
95 Civic Si
00 Yamaha R6
Old 03-12-2004, 08:39 PM
Re: Re: Blinker Problems - Honda Shadow 750
How would I go about testing it? (Manual shows only one relay.)
Fuses are all good.
Old 03-13-2004, 01:32 AM
EGcivicSi's Avatar
Yeah you should have only one flasher relay. Well you may have to do a continuity test. But before you go through that check the connections and make sure they all snug. Then I would suggest a continuity test to see where your short is. Sorry I cant be more help.
95 Civic Si
00 Yamaha R6
