Old 03-12-2004, 01:08 PM
abaird abaird is offline
starting problem??
My 1997 chevy Z71 has a starting problem. It has a vortec 350. For some reason this thing can sit in negative 30 degree weather for 3 days and start after turning over only two times. But if i get it warmed up good like maybe an hour or more of driving and then turn off and let sit for a couple of hours, it has to turn over for about five times longer before it starts. I have replaces plugs, wires, dist. cap, and rotor hoping this would fix it. Truck has about 96,000 miles. Is this just something i have to live with? Thanks alot.
Old 03-12-2004, 02:03 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: starting problem??
sounds like a bad ect(engine coolant temp sensor) it does the same job as a choke in older carburated vehicles.
Old 03-13-2004, 10:40 PM
northmansx northmansx is offline
try checking the fuel system, had similar problems on a 96 vortec 350, check in the search for hard starting, gm merlin has offered up some great advice and tips regarding hard starting trucks, he gives a step by step diagnosis in some of his posts try it, it's who i relied on,good man
Old 03-14-2004, 03:23 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
I had a 6.0L with basically the same problem. We ran pressure checks on the fuel system, which was okay and did a general tune-up, still had the same problem.
The GM tech told me all he could think would be that one of the injectors may be leaking fuel into the intake, on cold start the engine could easily handle the extra fuel, but on warm start it was the same as 'flooding' the engine.
I haven't pressure tested the injectors yet, but it makes sense to me.
Just a thought.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
