Old 03-12-2004, 10:57 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Cool Stripping chrome - my experience
Hello everyone
Wanted to share my experience in stripping chrome off parts, either those that don't need to be chromed, or those that need a better solution that what we get in the kit.
In a nutshell, all went well and smooth. It's quite easy, actually. As suggested, I used bleach to strip chrome itself. I did that to parts from two kits - a Revell AG Diablo VT and a Revell-Monogram GT350H Mustang. With the diablo the parts were clear of chrome after just several minutes spent in the bleach, the Mustang parts I left there for the night as the process wasn't as fast. Anyway, same result in both cases - all the chrome was gone. The bleach to use is the cheap one, one that has chlorine in it.
Now, as some of you know, there is a layer of clear paint underlying the chrome in most cases. It's really visible once you dry the part - it will be shiny. No biggie there too - after several hours in DOT4 brake fluid it was also gone, so parts are all clean plastic pieces now.
This was the first time I tried to dechrome anything, and if you want to do this, but are afraid that it's complicated - don't be, it's very easy and effective. Of course excercise caution when dealing with chemicals, gloves are highly recommended.
Keep modelling,
Alex
Old 08-27-2004, 12:27 PM
mstngcobrasvt98's Avatar
mstngcobrasvt98 mstngcobrasvt98 is offline
Send a message via AIM to mstngcobrasvt98 Send a message via Yahoo to mstngcobrasvt98
Re: Stripping chrome - my experience
im stripping some revell parts right now...how long does it take for the chrome to come off?
Just a good model of mine:
2 Fast 2 Furious Skyline
STOLEN!!!
Another go at it:
2 Fast 2 Furious Skyline.. Pt. 2
Old 08-27-2004, 12:33 PM
ales's Avatar
Forza Schumacher
Really depends, rangine from 15 minutes to a few hours. Just look at the part from time to time. And don't forget to strip the clear layer that is usually found underneath the chrome.
Old 08-27-2004, 12:38 PM
thanks for the quick reply...does the brand matter any?
STOLEN!!!
Another go at it:
Old 08-27-2004, 12:40 PM
ales's Avatar
Forza Schumacher
I've only tried one (ACE), but I don't think it would matter.
Old 08-27-2004, 05:31 PM
935k3's Avatar
935k3 935k3 is offline
If you want to strip the chrome and clearcoat nothing is quicker than regular(yellow can)Easy-Off oven cleaner. It takes about 10 minutes. It is not alway necessary to remove the clearcoat, it depends what paint you will be using over it.
Old 08-27-2004, 06:11 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Thanks ales, I'll have to try that some day. Sounds very easy.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 08-27-2004, 06:45 PM
well..now theres a problem. I had the parts in around 12:30, they sat in the bleech till 5 or so and nothing happened to them. Could DOT 3 brake fluid work too? I looked and I have no oven cleaner and can't get any CSC.
STOLEN!!!
Another go at it:
Old 08-28-2004, 01:26 AM
ales's Avatar
Forza Schumacher
What bleach did you use? Don't use the one that is supposed to be very gentle on the laundry - it contains no chloride, use the cheapest one you can get. Here is a pic of the rim I practiced stripping chrome on.
And here's the original
Old 08-28-2004, 10:52 PM
SkylineMan32
Guest
Posts: n/a
I use goo gone in a gerber baby food container
Old 08-29-2004, 11:51 AM
minniebanister minniebanister is offline
Gerber vegetables or cereals?
Old 08-29-2004, 12:12 PM
freelunch's Avatar
freelunch freelunch is offline
Use Easy-Off, it removes the bleach and the thick clearcoat in one application. You should really remove the clearcoat too, on the Revell Civic models its really thick and obscures detail.
1/25 Civic Link
Old 08-30-2004, 07:16 PM
007ightning 007ightning is offline
You can also try using Draino or Liquid plumber (the clogged drain stuff) I have used that with success.
John
Old 08-31-2004, 05:03 PM
racer917's Avatar
racer917 racer917 is offline
Hi to all,
Whenever I hear of using all sorts of stuff to strip chrome in ONLY a few hours or ONLY overnight I just have to shake my head. 935K3 got it right. Easy-Off oven cleaner. This stuff can get in done in a few minutes. You can put the parts in a zip lock bag, spray it and seal it. Trust me, within five to ten minutes you'll see results. And for even quicker results you can massage the parts inside the bag. After that simply wash it and presto. It's fast, relatively quick and it even comes in pine scent.
Old 08-31-2004, 05:09 PM
RallyRaider's Avatar
Zomby Woof
Why shake you head? Modelling isn't an Olympic event. It is a pastime best approached SLOWLY.
