Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-12-2004, 11:24 AM
oltos oltos is offline
Cold Starts/Transmission 03
Automatic transmission will not shift into overdrive after cold start. Cold means under 25 degrees. Dealer suggested letting engine warm, but still won't shift until engine is close to normal operating temp which can take 5-10 minutes or longer on cold days. Fluid is fine, car has 15k, 4 cyl. Dealers suggestion doesn't sound right. Any ideas?
Thanks
Old 03-12-2004, 01:29 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Cold Starts/Transmission 03
Many model transmissions normally have that behavior. I would bet you can't do anything about it.
Old 03-12-2004, 08:50 PM
Joe W Joe W is offline
This is normal.The engine must be at operating tempature to bring the ecm into open loop mode.(That is running off of the sensors.)The ecm won't allow O/D until these conditions are met.
Old 03-13-2004, 01:55 AM
Parmenides3 Parmenides3 is offline
Is there any way to save wear on the car in cold weather? All this warm-up time makes me wonder.
"A thing cannot both be and not be at the same time and in the same way." Aristotle
Old 03-13-2004, 03:26 AM
Brian R.'s Avatar
Resident Chemist
I just drive mine slowly until the tranny upshifts by itself. When the engine is cold, I don't take it above 2000 rpm.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
