Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-12-2004, 12:11 AM
harris145 harris145 is offline
18volts from alternator
i have an 83 ranger with a gm alternator on it i forget the amps i know that it is the common gm alternator though just in the last 3 months or so ive gone through 4 alternators that all are doing the same thing. after having them on my truck for about a week they start slowly putting more voltage out then eventually it will start to put out around 18 volts but not always it will go between normal and 18 volts. i had this gm alternator on my truck for about 2 years with no problems till now. all the alternators came from the same store. any ideas on what to check or what could be causing this problem would be great
Old 03-12-2004, 07:55 PM
lakerfan1784 lakerfan1784 is offline
Send a message via AIM to lakerfan1784 Send a message via Yahoo to lakerfan1784
i would be suspicious of the voltage regulator. You may want to get that checked out.
Do sober what you say you will do when you're drunk. that will teach you to keep your mouth shut.
