Prelude help
im jus curious and can i get some info.
is there a method of going all motor only and getting a 2000 prelude hitting 13-14s in the 1/4. and is so can u guys help a friend out and suggest ideas and how about if its a good idea thanks for your help im a newb by the way |
Re: Prelude help
Are talking about a stock motor for a prelude or hittings 13's 14's after upgrades?
he's talking about all-motor, which I'm defining as no FI, nor N20.
so simply bolt-ons, in order to "free up" power that is lost mechanically. |
Re: Prelude help
It's expensive, but there is a way. Here's an incredibly rough overview of it:
First off, get your I/H/E done. Then, to keep up with the greater flow, you'll want to start getting more fuel via fuel pump, fuel pressure gauge, and a fuel computer. You need an wideband O2 sensor and a dyno to tune it afterwards. You can start messing with compression after this, but its not a good thing for a daily driver (premium pump gas is slowly becoming unusable.. you need race gas). To run it higher, you need to get forged pistons. You can't do this without sleeving the block. Be warned, going too high will mess with your timing components. You'll want stronger everything; rods and valves. Tune, tune, tune. Going to a dyno is a necessity, not an option.
![]() 1993 Mazda Rx-7 Touring Ricer Extraordinaire Last edited by AcesHigh; 03-12-2004 at 12:16 PM. |
Re: Prelude help
i see, that sounds pretty complicated
but isnt there a way to make the prelude lighter and removing stock parts and adding performance parts... would that decrease the 1/4 time by a few seconds lik for ie. i/h/e and stuff like intake minifold and so on woul those stuff make a difference? |
Re: Re: Prelude help
I/ h/ e is a good start and IMO the best intake for a 5th gen Prelude is the JDM Prelude Type-S intake system with a K&N drop in filter. 5th gen headers are already well designed so donīt get something "cheap" like a DC header or anything like that. Greddy, Mugen, SMSP,.... are well designed headers for example. When it comes to exhaust systems Mugen and Thermal are good for example...Use the search function for these parts and you will get some more ideas about what is good an what not. Getting a new intake manifold is not a good idea as far as I know except if you have already done some internal work like ported/ polished head, new cams,.... And donīt waste your money on ignition stuff because the stock ignition is already damn well designed, too. Hope it helped a bit and please correct me if anything is wrong!? |
Re: Prelude help
thanks for your info man
