Old 03-11-2004, 07:48 PM
masterbs masterbs is offline
Unhappy 1993 Grand Am Problems
I have 2 current problems with this car. I have the 3.3 liter SE model. I can't find the low port for the air conditioning, I did find the high port. Second, what would cause the car to idle up and down while in park. I have done a full tune-up: new wires,ac delco plugs, air filter, pcv valve, fuel filter. Thanks for the help.
Old 03-12-2004, 08:06 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: 1993 Grand Am Problems
check out the O2 sensor and the maf sensor. Also if the throttle position sensor is going , it will idle all over the place. Others may have more to say...
Old 03-12-2004, 02:33 PM
achievasc92 achievasc92 is offline
The 3300 will idle up and down 50-75 rpm without haveing any major problems, its just a moody engine. lol Have you ever had trouble starting the car in par? and had to move it to nuetral for it to start? if so it may be your park/nuetral switch, very common to go out on older GAs
Old 03-12-2004, 09:10 PM
Thanks for the help, I will check it out more this weekend. I wanted to charge my wife's air conditioning also, but I can't find the low port on this car. The high port is on top, right behind the radiator. This would help out greatly if anyone knows where it is on this car, 1993 Grand Am, 3.3 liter.
Old 03-20-2004, 08:38 PM
cbyrd cbyrd is offline
ideling problem...
if you can't find the problem,check all your vaccum hoses...especially the one on the right side of the black box right above your intake manifold.i had a small tear in mine and it did the same thing.your problem sounds like a vaccum leak to me.hope that helps.
Old 05-10-2004, 08:31 AM
93_grand_gt 93_grand_gt is offline
I know exactly what your problem is i think. When it is in park if the little indicator light on the P is blinking or goes out and then it starts to idle up and down just give it a smack and the light will come back on and the car will idle fine. I had the same problem with my 93 grand am gt 3.3 L and i replaced all kinds of sensors but nothing worked until i had some help to figure this problem out. email me back at [email protected] if you need anymore help
Old 05-10-2004, 10:25 AM
I couldn't find the low port on my 3300 either, So I just gave up and ditched the AC
Old 05-10-2004, 10:39 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
The low port is usually located on the AC compressor itself. I think it has a blue color cap.
Old 05-24-2004, 07:20 PM
denny1952 denny1952 is offline
I have a 95 grand Am And I can't locate the low port either. Can you recharge the air conditioning of these models? I can see the high poing right in the front behind the radiator. Any help would be appreciated, it was 92 today and driving on I-95 with the windows down is not a whole lot of fun. Thanks.
Old 05-29-2004, 04:14 PM
helpme0768 helpme0768 is offline
On my 94 grand am the bottom port is right down below the top port.frount bottom left.Its easy to see on mine and also I can recharge my air.
Old 06-11-2004, 01:06 PM
JuniorTech JuniorTech is offline
Hey masterbs, try lying on the ground in front of your 1993 Grand AM
and look up right under the front of the car. You will see the low side
AC port.
Old 06-11-2004, 08:29 PM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Does that are have a Mass-air flow sensor? It might be dirty. You might also have a slightly miss adjusted TPS(throttle postion sensor), or your IAC (idle air controller) might be dirty, or bad.
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 03-19-2005, 06:52 AM
Woohan Woohan is offline
Send a message via AIM to Woohan Send a message via MSN to Woohan Send a message via Yahoo to Woohan
On a 3300 model Grand AM the low side port for the AC in on the bottom of the car. It located on the passenger side of the oil pan. hope that helps.
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
1st post))) 1993 Grand am problems JackPumpkinKing Grand AM 1 10-31-2008 06:37 AM
1993 Grand Cherokee Trailer Hitch Replacement Problem rjg66 Grand Cherokee | Grand Cherokee SRT8 2 02-05-2006 05:31 AM
1993 Grand Am drive problem motored Grand AM 3 02-25-2005 03:51 PM
1993 Grand Cherokee problems HELP MoparFamiily Grand Cherokee | Grand Cherokee SRT8 3 06-15-2004 05:49 AM
