Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 03-11-2004, 06:28 PM
JimJ48 JimJ48 is offline
Angry Installing Amp And Sub int Stock Head Unit
I am having some trouble installing a amp and sub into a stock radio. I amp works and the sub works. The amp will turn on but will get nothing from the sub. I got the Level Output Converter hooked up but I am not sure if its correct . Any suggestions or anyone know the right way to do so
thanks
Old 04-10-2004, 09:07 PM
onemeantaco onemeantaco is offline
Re: Installing Amp And Sub int Stock Head Unit
I had a problem very similar to that I had to take the 2 rca plugs where it goes into the conv. and get another plug that has 1 male end with two female ends plug those together and just forget about the other plug on the conv. if that makes any sence
Old 04-11-2004, 07:05 PM
supra17 supra17 is offline
take it 2 best buy they installed my amp and sub with no problem
Old 04-20-2004, 09:30 AM
evilmind evilmind is offline
the problem with this is you lose two of your speekers. first make sure you are hooking up to the correct ones. you want to cut the rear sweeker wires. touch the +/- to each side of a battery the speeker will pop telling you with speeker that wire powers. if you have one fr and one rr it wont work. if this is hooked up right and does not work there should be an extra wire, brown or black, hook this wire to your stereo grownd. make sure all your speekers work before you hook it up. good luck
installing amp and subs mipthat Grand Prix 1 03-27-2006 06:11 AM
Connecting amp and subs to stock infinity joemathews Off-Topic 12 05-18-2004 11:12 AM
upgrade amp and sub to stock radio? holocaust Car Audio 1 03-20-2004 05:37 PM
add an amp and sub to stock radio 2000accord holocaust Accord/TSX/Accord Hybrid 0 03-20-2004 07:11 AM
Installing Amp and Subs in 2002 Maxima jasonphd Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 03-20-2002 07:10 AM
