Old 03-11-2004, 05:58 PM
papdetomaso papdetomaso is offline
Ball joint tool
Just replaced the axel on my 90 HB. Spent two hours beating on the ball joint with a pickle fork. Does anyone know a of good tool, the kind you press it off with?...thanks...Pappy
Old 03-11-2004, 06:13 PM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
Hey man, I've always used a pickle fork, and thats what we used in the shop where I worked, thats what always worked best for me, whats the problem with that? Is that not workin?
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 03-11-2004, 06:16 PM
BullShifter's Avatar
The best way I find is the back the nut all the way down so it's flush with the bolt part, then smack the nut with a hammer. Pickle forks rip boots, NOT GOOD. IMO a puller is better than a fork, but the hammer is the fastest.
Old 03-11-2004, 06:23 PM
Re: Ball joint tool
My bad, didnt even think of that, usually when I'm pullin a ball joint, im replacin it, so it doesnt matter if the boot rips...nice call man. Thanks for coverin me
Updated 1-23-05
Old 03-11-2004, 07:18 PM
pickle fork
Yes, the pickle fork works, but the job took four times as long and as mentioned above it's hard on ball joint boots. I just wondered if anyone had a specialty tool they used for this job... thanks for the responces...Pappy
Old 03-11-2004, 07:24 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Ball joint tool
the specialty tool is a big ass ball peen hammer. the key is, loosen the nut to the end of the balljoint, then look on the lower control arm, theres a flat knob that kinda pokes out right on the end. hit that spot as hard as you can with the ball peen, and it will come loose. then just take the nut off the rest of the way, and you are set. i wouldnt recommend actually hitting the nut or balljoint itself, because you can mess up the forums.....erm, i mean the threads....yeah
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-11-2004, 08:12 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
Re: Ball joint tool
i've never ripped a boot wiht a picklefork, most of the time i use the airhammer tho
if it's really stubborn i use the hammer type with a 3lb hammer.. rap on it once or twice and she pops right off
Ball joint installlation for 2001 Taurus SEL Doug Tatham Taurus | Taurus Wagon 10 09-28-2020 07:37 AM
ball joint or tie-rod end? thinmint Dakota 1 03-07-2010 10:39 PM
Ball Joint question - confused... caffeineaholic Caprice 8 12-19-2009 06:17 PM
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
