Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-11-2004, 05:17 PM
Joe Trinkley Joe Trinkley is offline
Circuit Opening Relay Infomation
1985 toyota efi 22r automatic 4x4
my circuit opeing relay was finally found, it took me 2 hours to find it and about a half to get it out....it is located behind the passenger front speaker. to remove get a 10mm socket and a 1/4 drive rachet with a 5" extension....remove the glove box and use that as an access hole to remove the bolt that holds the relay in place....then there are 3....not 2 clips that hold the relay to the harness.
I'm supplying this information because it's not in the books and not in any forums I've searched.
Now if I can only find the check connector so I can x out my timing advance by jumping the Fp and +B connectors.........
Joe
Seeking advice on an open/short circuit finder, wire tracer jonque Scanners and Diagnostic Tools 0 05-10-2009 03:54 AM
circuit opening relay quickywd01 Pick-Up 6 09-05-2008 07:57 AM
Injector circuit open eduardohm78 Silverado 0 09-04-2005 08:56 PM
Circuit Open error. l1r Grand Cherokee | Grand Cherokee SRT8 0 07-10-2005 11:39 AM
Vehicle speed signal circuit open chicksmom Venture 5 02-15-2005 11:34 AM
