Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 03-11-2004, 03:37 PM
caper caper is offline
Oil light blinking
hey guys, i have a 924S 1988...my oil light keeps blinking...my oil level is good and ive been using mobile one oil...i cant figure out what the deal is...its also idling pretty rough, it runs fine after about 1100rpm with gas but it fluxes under 1000 and sounds like its gonna die but just idels back and forth from 900-2000 rpm at idle when warm....
Also i have a grounding problem....do you guys have any sugustions about grounding the ECU and battery better?
thanks
Brian
1988 924S
Old 03-14-2004, 06:21 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
Hi Brian, I'd suggest you replace all your grounds with new grounds, after 15 years, corrosion can prevent good grounding, and the factory grounds weren't the best to start with.
If you don't feel like springing for new grounds, you can just pick up a can of electrical cleaner, sand down your original grounds, and give them a good spray of the electrical cleaner.
Probably the best bet would be to replace your battery and alternator grounds with good AWG 4 guage or 2 guage wire, and soldered brass lugs. I converted my 924 to GM style bolt in battery terminals, since corrosion isn't an issue with those.
Grounds are really easy to make, you can buy the wire in a spool, and then you just have to cut it to length, strip the ends, and either solder or crimp the lugs on. Then it's just a matter of unbolting the old ground, and bolting the new one in.
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Oil light blinking clemsonfansc Intrepid 7 03-02-2011 06:47 PM
94 Accord EX oil light xxGriffonxx Accord/TSX/Accord Hybrid 4 10-18-2009 01:12 AM
98 taurus oil light blinking samurch Taurus | Taurus Wagon 16 11-25-2005 10:12 AM
82 convertible oil light blinks missouri Rabbit Rabbit 1 04-04-2005 09:09 PM
89 lx oil light blinking RoBoDEATH Accord/TSX/Accord Hybrid 1 11-21-2002 10:11 PM
