Old 03-11-2004, 02:51 PM
drew23 drew23 is offline
Send a message via Yahoo to drew23
Angry oil pressure
I have a 2000 cherokee and i took it in to the dealership last week because when i start it up oil pressure reads 50-55lbs but as I drive along pressure goes down and at stop it goes down to 5lbs. So the dealership puts a new oil pump in and guess what, that was not it. Does anybody know what is going on, they also tryed a new sending unit so it was not that. I run 10w30 oil. And like i said i have good oil pressure at cold start up. When I am traveling 70 mph my pressure is 20lbs and at stop it drops to 5lbs and the check guage light comes on. If i down shift i can bring the pressure up. Please help thank you
Old 03-12-2004, 05:40 PM
Dale Aeppli Dale Aeppli is offline
Re: oil pressure
YOU COULD INSTALL A MECHANICAL OIL PRESSURE GAUGE SEPERATLY & GET A TRUE READING. THEY'RE NOT EXPENSIVE & THEY COULD SAVE YOUR ENGINE JUST INCASE THE ORGINAL GAUGE GOES SOUTH ON YOU.
DALE [email protected]
Old 03-13-2004, 01:23 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: oil pressure
If the pressure readings are correct, you have an internal oil leak. Worn camshaft bearings can produce this effect.
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
