Old 03-11-2004, 02:51 PM
martle martle is offline
Send a message via AIM to martle Send a message via Yahoo to martle
Wheel bearing replacement $$
Don't know if this has a straightforward answer but figured I'd give it a shot. I'm taking my car (99 GA) into dealership tommorrow. I'm pretty sure my wheel bearing needs to be replaced. Shimmy's during turns, has been getting worse lately. Started to notice after hitting a pothole. If it is that does anyone know how much it costs approximately to replace a wheel bearing? Is it worth it to shop around since it almost always cost a lot more to fix something at a dealership.
Thanks
Old 03-12-2004, 08:28 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: Wheel bearing replacement $$
Are you sure its a bearring? Could be a warped rotor rubbing against your brake pads and if its that , id suggest you fix it asap cus it may be salvageable on the rotor lathe and saves what pads you have left.
Old 03-14-2004, 04:03 PM
AntiF AntiF is offline
Send a message via AIM to AntiF Send a message via Yahoo to AntiF
My 01' GT recently needed a bearing replaced. Grand total at the local dealership? $800. Talk about starting out your vacation the wrong way
Old 03-22-2004, 08:34 PM
jcl27 jcl27 is offline
I work for a general motors dealership. A tipical wheel bearing replacement with a gm part is around $500 dollars a wheel bearing,give or take.
Old 03-23-2004, 01:23 AM
You didnt have warranty left? Ouch. After reading some of these posts long time ago on my freinds account I got nervous and bought extended bumper to bumper 160,000 mile warranty for 2000 bucks and Ive only had 800 dollars of a return from it in 2 years so now Im wondering if it was worth it.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 03-23-2004, 06:53 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Re: Wheel bearing replacement $$
Is your warranty up yet? If not don't worry, if it is close to being up take it in and have them check out the car bumper to bumper and see whats wrong with the car.
One trans or engine problem can cost more than 2000 dollars, its better to have an extended warranty and not have to woory then worrying on how you will pay for the repair when it breaks!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 03-23-2004, 07:01 PM
Ya , I know I bought peace of mind , I dont know too many people who drive the cars very hard. I see them baught and trashed real quick but never seenem in action. Not many anyways.
Old 03-24-2004, 01:50 PM
rurbaniak rurbaniak is offline
Thumbs up
Shop around! I just hard my front bearings replaced on my 2000 Grand Am SE and it cost $500 Dollars total!!
Old 03-24-2004, 04:15 PM
h8thiscar h8thiscar is offline
I had to have both my front hubs replaced after only 120,000 kilometers on my 99 piece of crap. GM of course made sure that you can't just replace the bearings! The entire hub assembly needs to go, including the ABS sensor.
I had the first one done at a dealer for 600 dollars. The other I had done at an independant shop for 400 dollars. Less then 8 months later, the GM part replaced by the dealer failed again... not the bearing mind you but the ABS sensor!!
Do not give GM any money at all. Go to a car parts store and buy yourself a new hub assembly. Then take the part to a small trust-worthy garage and have them install it. Or if you have the ability, do the job yourself. It is not that complicated as long as you have the tools and patience and you can refrain from beating the hell out of the car with a torque-wrench for costing you yet more money.
Old 05-23-2004, 06:12 AM
racerguy4u racerguy4u is offline
if u wanna do it cheaper buy it yourself and do it yourself its not that hard and theres no special tools. i replaced both of them on my 99 took about 2 hours
Old 05-23-2004, 09:34 AM
achievasc92 achievasc92 is offline
do it yourself, its not hard at all especially if you have airtools.
